Working eBay Techstream
  • As some will have guessed when it comes to using Techstream I'm pretty useless. Give me a house or a factory unit to wire up or repair scientific equipment no problem but this has me stumped.
    Anyone in Perth area (100 km radius) willing to run me through operation I would be happy to come to you.
    Terry
    • Hi there, my cable came with Techstream Ver 10.10.018. I managed to get the cable recognised on my 64bit Windows 8 computer, but the Techstream software requires a license key ;-( Have been looking for downloads, but many are blocked by my AV software, obviously for good reason. Can anyone recommend a link to a working download please?
      • Terry you got your techstream running yet?? I am in Heathridge and would like some help with mine also,,
        • Originally posted by raydes View Post
          Yes my computer savvy mate loaded the software and Dave (Bush Basher) showed me how to use it to check engine functions.
          Loading software correctly is critical so as not to default to genuine Techstream requiring access codes.
          • Gents.....
            I've also recently purchased the Techstream of ebay via obdfamily seller and its looks like I've run into the same problems as others and after reading through previous posts I can't seem to find the answer I need.
            I select "Other" for Country/Region.
            I then select "Australia" and click OK
            Then this box comes up asking for a New Key to be entered:
            What or how do I get around this?
            Thanks in advance......
            Rob
            • Does anyone know of a good one of these to buy.
              • Problem now all sorted..... reloaded files again and all working now...
                Originally posted by rob_macca67 View Post
                Gents.....
                Rob
                • Could someone post a link to a good step by step guide to setting this up. I have just bought one on ebay and am not super computer savy.
                  • I purchased from ebay seller obdfamily as mentioned earlier in this thread, and it arrived in under a week from hongkong. The first time I've had something arrive so quickly from HK!
                    Ordered on the 7th of July, arrived about the 13th of July.
                    • does anybody have the mini VCI driver available? I don't have a cd drive for the disc
                      • Gave up on sourcing a driver... Wasted too much time looking around! Used virtual box and installed a copy of windows xp and it all worked immediately.
                        1. Install techstream. Dont open it.
                        2. Plug cable into car. Go second start option where the instrument panel lights up.
                        3. Plug cable into laptop.
                        4. Install driver.
                        5. Run techstream.
                        How does one get "cold" start injector readings? Just do the test after starting it in the morning?
                        Good to finally be rid of passenger seat alarm when the dogs up front or j have shopping on the chair!
                        • Has anyone checked to see if you can see DPF info on Techstream for the 1GD-FTV?
                          • V11 Now available?
                            Hi guys, never used techstream but noticed on my first google search Version 11 is out but on Ebay V10 seems to be the version available. I want to just check my injectors like everyone else and I think I this right, buy the cable which is 16pin and the CD that comes with it should have techstream on it. I assume you'll get a key with it not just some free version where you have to pay for registration etc? Thanks heaps in advance for your help. I am computer savvy enough to get it working when I get it but to actually ensure I get the right version is my worry. I am currently connected to the OBD2 port with a little wifi module that I use to check my battery, turbo and other temps etc that are not displayed on the dash. I will of course have to remove that but otherwise yeah keen for some help.
                            • Just a heads up for anyone looking to buy the techstream cable and software. I took the advice on here and bought a 10.30.029 set up from obdfamily on eBay. Package arrived in a week with cable and mini cd with instructions and necessary software. I am running it on a asus notebook with Windows 8 64bit. I had issues with the registration key and the mcvi drivers, for some reason neither would work properly. After a few attempts I contacted obdfamily via eBay. They got back to me within the hour and offered to carry out the set up remotely from HK / China via teamviewer software. I set up teamviewer, emailed registration number and pass code and they loaded the software onto my computer last night - finished at 11pm our time or 9pm for them on a Saturday night! Best customer service and follow up that I can ever remember. Just ran the cold start tests on the Prado and it is all good. One feedback injector value a little high, but everything else spot on. It worked flawlessly. It's probably the best $70 that I have spent on any vehicle, worth the cost and the bit of stuff around with the software yesterday for the peace of mind knowing that the injectors are pretty good. I will drop the oil next week and photograph the pick up screen to make sure it is clear. It's a late 2008 D4D manual with 155,000 kms. I believe the injectors and seats are original. I would strongly recommend OBD family on eBay if you are thinking of getting the techstream cable.
                              Regards,
                              • Originally posted by Dhm77 View Post
                                Regards,
                                Hi Dave,
                                mine came with both 10.10.018 and 10.30.29 and I have Win 7 64bit. Thought it was 32bit.. yay me for not checking. Can you remember what they did for the MVCI driver. Did they go into the temp directory and fiddle around or did they have a dedicated driver for you?
                                Dan
