Nope, they have closed that down
Working eBay Techstream
Actually, I reckon the Techstream could work in your favour. If the owner can keep an eye on things then when they require attention they can take it to a good mechanic like yourself and get it fixed properly. The alternative is without the device, their injectors fail causing damage that Toyota wants a ton of money to fix.Originally posted by Talktheroo View PostWait a minute, it cuts me out as well.
Catch you later, John.Dave
G'Day I have a question with the vehicle connection wizard. It automatically comes up with KDJ for Model Code. For Vehicle spec it comes up with 1KDFTV.
Under Option what do I select:
0908-1007
1007-1110
1110-1206
1206-1308
1308
-0608
or
0608-0908
Some have sub menus when you select them.
Winston.Winston.
WinstonOriginally posted by winniliss View PostG'Day I have a question with the vehicle connection wizard. It automatically comes up with KDJ for Model Code. For Vehicle spec it comes up with 1KDFTV.
0908-1007
1007-1110
1110-1206
1206-1308
1308
-0608
or
0608-0908
Winston.
Once you have 1KDFTV, you will see a list of options for the model year in the drop down menu
In selecting the model year, the first two digits represent the build year, and the last two the month.
Pick the range, that you build date is between.
Robert[B]Robert
I don't know if it is coincidence but if you go to toyodiy.com and select
a 2008 Prado and then injector pump for instance you will notice at the top
left of the screen 0608.
If you do the same for a 2011 it shows 0908.
Could be pure coincidence or possibly a model code?
LeighHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
YesOriginally posted by D4D View PostThanks Robert, so mine being a June '08, I should select 0608-0908?
That range would be for a vehicle from Aug 2006 to Aug 2009
Robert[B]Robert
I selected the last one Since mine was Aug 09 after reading a link on Hilux forum. All working.
I have an Aug 2009 GXL with 104500km on the clock. My injector feedback values are as follows:
Inj 1# .3
Inj 2# -1.6
Inj3# 1.8
Inj4# -0.8
Injector volume 10.3
Winston.Last edited by winniliss; 17-10-2013, 05:40 PM.Winston.
Was that build date or compliance/delivery date. Mine is registered and complianced as January 2009 but the build date is November 2008. It didn't get off the boat at Fremantle until first week of January 2009.Originally posted by winniliss View PostCheers,
Inj 1# .3
Inj 2# -1.6
Inj3# 1.8
Inj4# -0.8
Winston.Dave
The last of the breed then.Dave
Originally posted by adrian5800 View PostI've just installed techstream on my laptop and it runs fine on 32bit Win7 so long as you set the .exe to XP3 compatibility first. Works great on my 1KZ-TE with M-OBD
Not bad for $28 posted http://tinyurl.com/l9276l6
[ATTACH=CONFIG]12668[/ATTACH]
Ades
Hi Ades
What info do you get from the 1KZ??
Matt2003 Prado Grande TD Auto Pearl White
