Working eBay Techstream
  • #46
    Nope, they have closed that down
    Gavin
    2008 KDJ120
    • #47
      The site looks like it is working again so give it a go.
      If you can't download it we can maybe try something else.
      • #48
        Wait a minute, it cuts me out as well.
        Catch you later, John.
        Actually, I reckon the Techstream could work in your favour. If the owner can keep an eye on things then when they require attention they can take it to a good mechanic like yourself and get it fixed properly. The alternative is without the device, their injectors fail causing damage that Toyota wants a ton of money to fix.
        • #49
          X2 Bushbasher. At least I don't have to spend $400 or so on an Intelligent tester...
          Winston.
          • #50
            G'Day I have a question with the vehicle connection wizard. It automatically comes up with KDJ for Model Code. For Vehicle spec it comes up with 1KDFTV.
            Under Option what do I select:
            0908-1007
            1007-1110
            1110-1206
            1206-1308
            1308
            -0608
            or
            0608-0908
            Some have sub menus when you select them.
            Winston.
            Winston.
            • #51
              I dunno, I just select the first one. It would be good to know what the options actually mean.
              • #52
                0908-1007
                1007-1110
                1110-1206
                1206-1308
                1308
                -0608
                or
                0608-0908
                Winston.
                Winston
                Once you have 1KDFTV, you will see a list of options for the model year in the drop down menu
                In selecting the model year, the first two digits represent the build year, and the last two the month.
                Pick the range, that you build date is between.
                Robert
                [B]Robert
                • #53
                  Thanks Robert, so mine being a June '08, I should select 0608-0908?
                  • #54
                    I don't know if it is coincidence but if you go to toyodiy.com and select
                    a 2008 Prado and then injector pump for instance you will notice at the top
                    left of the screen 0608.
                    If you do the same for a 2011 it shows 0908.
                    Could be pure coincidence or possibly a model code?
                    Leigh
                    • #55
                      Yes
                      That range would be for a vehicle from Aug 2006 to Aug 2009
                      Robert
                      [B]Robert
                      • #56
                        I selected the last one Since mine was Aug 09 after reading a link on Hilux forum. All working.
                        I have an Aug 2009 GXL with 104500km on the clock. My injector feedback values are as follows:
                        Inj 1# .3
                        Inj 2# -1.6
                        Inj3# 1.8
                        Inj4# -0.8
                        Injector volume 10.3
                        Winston.
                        winniliss
                        Winston.
                        • #57
                          Inj 1# .3
                          Inj 2# -1.6
                          Inj3# 1.8
                          Inj4# -0.8
                          Winston.
                          Was that build date or compliance/delivery date. Mine is registered and complianced as January 2009 but the build date is November 2008. It didn't get off the boat at Fremantle until first week of January 2009.
                          • #58
                            Compliance states Aug 09. Build date (found the sticker on the door pillar on the front passenger side) July 09.
                            Winston.
                            • #59
                              The last of the breed then.
                              • #60
                                Originally posted by adrian5800 View Post
                                I've just installed techstream on my laptop and it runs fine on 32bit Win7 so long as you set the .exe to XP3 compatibility first. Works great on my 1KZ-TE with M-OBD
                                Not bad for $28 posted http://tinyurl.com/l9276l6
                                [ATTACH=CONFIG]12668[/ATTACH]
                                Ades
                                Hi Ades
                                What info do you get from the 1KZ??
                                Matt
                                2003 Prado Grande TD Auto Pearl White
