Working eBay Techstream
  • It is what i use.
    • Thanks for the helpful information, I looked at the above links and noticed "Prado up to 2015" What do you recommend for a 2015 Sept build GXL please?
      • Originally posted by Mr ok View Post
        Hi David.
        I think the issue is more around the compatibility of the cable/the cable driver/the operating system and techstream version used. In my opinion, forget Ebay and buy the hardware direct from the site you download the program from.
        I have no problems with windows 10 with this setup. Only 5 easy steps.
        1) Buy this cable, this cable can do the key programming.
        http://www.obdii365.com/wholesale/vx...sae-j2534.html
        2) Install the cable driver for the cable from the disk that comes with it.
        3) Download and install the latest program version. (Newer version than the other link)
        http://blog.obdii365.com/2017/05/09/...free-download/
        4) Replace the installed mainmenu.exe file in the folder (C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin) with the one that comes with the downloaded zip file.
        5) Work out how to use the program.
        Thanks very much for your help here Mr OK.
        Before I hit the buy button, how recently did you buy yours? Also, I weary of Chinese copies of these tools, do you know if this is a Chinese copy or the real deal?
        I Autel range have been copied for years and the copies are shit. :P
        [B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
          Hi David.
          hey mate when you turn it on , how do you work out what your car is by the numbers that come up ??
          then when i start the car it goes off & i have to re pick the car again ??
          any idea's ?
          cheers James
          • Did you swap from the standard US Area?
            Settings, Area, 'Other' then select -> 'Australia'
            When you 'connect to vehicle', select the date range, ours is 0608-0908 (Manufacturer date is on the door pillar: YYMM)
            • Originally posted by photoprado View Post
              i will have another go when i get back ( or you can come and show me !!)
                Hi David.
                Hi,
                I need some help as the program won't allow me to 'connect to vehicle' as it comes up with a software ID box requiring me to enter a 'new key'. (ie registering the program) No matter what I do I can't get past it - cancelling it or ignoring it won't work.
                Background
                1. I purchased the program and got someone to install the program (version 12.10.019) on a windows 10 laptop as suggested above from Mr Ok.
                Today I tried to run program by:-
                2. Opened up Techstream on laptop.
                3. plugged in cable to computer and then connected to car OBD2 port.
                4. Turned ignition key on Prado to acc. (pressing button twice) did not start the car.
                5. Selected 'connect to vehicle' - BUT it won't allow me to. Instead a box pops up with the tittle
                'Software ID' which requests me to enter a 'new key' I can't by pass this or progress any
                further or enter my car details etc.
                Note:- I do have my WiFi turned off on this laptop as it is solely only for Techstream whether this made any difference?
                Has anyone come across this problem? What have I done wrong? How do I fix this?
                thanks in advance David
                Bluedog16
                • Did you or your helper do this?:
                  • Hi photoprado,
                    My helper said he followed those instructions which makes it puzzling?
                    thanks David
                    • Do you still have the CD?
                      Have a look at the directory (C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin) and see if there is only one mainmenu, or is there one mainmenu.exe and another mainmenu.xxxx Look at the date of the files. If there is an extra, check if the newer version named differently to mainmenu.exe and the original is still there. If so, remove the original mainmenu.exe and rename the newer version back to mainmenu.exe
                      If there is only one mainmenu.exe maybe delete that mainmenu.exe from the computer at (C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin) before again replacing it by unzipping the replacement file.
                      • Hi all,
                        I have verion 12.xx of techstream running fine on an old laptop but it seems I can communicate with the engine ECU - other systems work fine??
                        Not sure if my cable is to old as ive had it a few years... I recall a comment about canbus?
                        Does anyone in Adelaide Metro have a cable that works on a 1GD that I can borrow?
                        Micheal.
                        • Originally posted by Bluedog16 View Post
                          Hi,
                          Background
                          When you were presented with the box asking for a key did you copy and paste the one supplied with the downloaded program?
                          I ordered a lead yesterday from China so it will be while getting here but downloaded the program and changed over the .exe and then changed the key and it looks like it would work just fine if I had a lead! (Windows 10 64 bit)
                          I hope when the lead arrives it will work as I chose a Chinese cheapo against the good advice above that the best one would be from the site offering the download. Anyway I will post the results, I hope to be able to work out some pids for torque pro with a bit of packet sniffing, sounds like you could be arrested for that.
                          Sorry 120D4D if I was anywhere near you and had a lead you could gladly borrow it.
                            Thanks photoprado - will check this out
                            David
                            • [QUOTE=JohnLynn;577563]When you were presented with the box asking for a key did you copy and paste the one supplied with the downloaded program?
                              thanks John -I didn't know that a key was supplied as I had a helper set it up for me. My problem could be as simple as locating that key. I will check it out. Is the key on the CD as I did not get anything on paper?
                              thanks
                              David
                              Bluedog16
                              • Yes in the downloaded folder it is on a little notepad file called key.txt Best of luck, I may be asking you some questions about the program before my lead gets here, although I have had a message saying it has been dispatched. I could PM it to you if only the PM system worked. John.
