Originally posted by berniebgf
View Post
I have had a very quick skim through the 11 pages, so if I missed it sorry, but is it possible to mount an antenna on the bracket or weld something onto it.
I would like to fit one to boost phone reception, this would make for a practical solution. Fitting a bullbar seems overkill just so I can fit a bracket for an antennastepped up the a 200 LC for towing,
no clearance issues, just don`t have the roof rack permanently fitted. Kaymar make something
http://www.kaymar.com.au/vehicles/toyota/prado150.phpstepped up the a 200 LC for towing,
the really good ones for vehicles are the 1mtr long thicker broomstick antennas, they still get respectable results even with the long rf lead they come with. I used one extensively for my nextg modem, a telstra Turbo Elite MF60 that has an external rf port. Its surprising what range you can get with it.Originally posted by MalcomM View PostIf its only a phone antenna, you can get ones that stick to the glass. Otherwise thats a long cable run which is not a good thing for RF.
The magnetic base stuff is good on paper or manufacturers rating, but it doesn`t deliver in the real world. Other small antennas only pick up a few db, which is better than nothing, I guess.
Anyway, that is what I have got and can always mount it on a caravan on a bracket so I can fold it down.
I wanted to use one in the car and run the cable to a phone cradle, but may have to look at a different antenna set up for the car.
The loss in coax cable, whether its a 1m run compared to 3 m is not worth worrying about.Last edited by maxjj; 07-07-2012, 08:09 PM.stepped up the a 200 LC for towing,
Ill take one lol2005 Toyota Prado Grande 3.0 TD - ARB Deluxe winch bar, Avenger 9500lb winch - nylon rope, Safari Snorkel, DP Diesel Chip, Lightforce HID 240's 50w, Oricom UHF, Bushranger Mud Tamer mats, Toyota Genuine Tow Bar, Toyota Genuine bonnet protector and headlight protectors, ARB Roof top tent and awning, ARB dual battery system with Red ARC and Optima deep cycle battery, Max Trax, ARB Compressor and Rear Air Locker, Waeco 50L fridge/freezer.
Hi Andrew,Originally posted by amts View PostI also have a bolt with a hole drilled through the middle that has been re-plated and heat treated to maintain the strength of the bolt. This bolt goes on the spacer bracket through the door.
I don't need the spacer kit any more, but I would like one of these bolts. Possible?
Cheers,2008 D4D M6 GXL [MT ATZ-P3][Whitey's Ironman 45710FE/45682FE+KTFR101H/Dob487][extended Roadsafe links][Polyairs][DBA T3/T2][amts diffdrop & recovery points][Tin175's stone guards][Bushskins BashPlate][ARB Sahara][IPF 900s][Snorkel][WindCheetah][MaxTrax][IC-440][Parrot Asteroid][ARB Fridge][Lifestyle 2nd Row Fridge Mount][ARB Compressor][Thumper][SandGrabbers][Cargo Barrier][Tigerz Awning][MCC Rear Bar]
You taking orders for them yet Andrew?
I would like one if so.2007 3.0L D4D GXL, ARB Deluxe Winch Bar, dual batteries, Bilstein/Lovells 2" Lift, Mickey Thompson ATZ 4 Ribs, ScanGauge II, UHF CB & HF/VHF/UHF Amateur radios
[img]http://www.fuelly.com/smallsig-metric/57576.png[/img]
[URL="http://www.pradopoint.com/showthread.php?21244-Homers-07-GXL-D4D"]My Rig Buildup[/URL]
Sorry, not quite yet. The pole isn't that great after using while away. The screw lock mechanism will probably not last. MalcolmM pointed me to something else and these poles looks a lot more long lasting and more readily available at Bunnings. Here is the link to the pole http://www.austbrush.com.au/extensio...dual-lock-pole. Unfortunately, the pic on the website does not appear.Originally posted by Homer View PostYou taking orders for them yet Andrew?
This website has the picture of it http://www.unipro.com.au/index.php?p...mart&Itemid=43
The locking mechanism is more robust and the height is at set heights. You can probably drill new holes into the aluminium extrusion. The yellow bit is fibreglass (wished it wasn't yellow, though).
The aim is to then use the ally cast tip as the base for the light to mount to and the light can then be removed when travelling. I had 2 lights up top and they make the whole thing top heavy. The next thing is to make the light swivel. More drawings to come.Last edited by amts; 18-07-2012, 12:15 AM.
Here is the CAD model of how the light is assembled on the cast ally adaptor from the telescopic pole.
The M8 bolt that comes with these types of lights is replaced with a longer bolt with a reduced M5 thread at the end. The red washers are nylon washers which allows the light to swivel. The dark green washer is a custom washer to provide a seat for the M5 nylock to bolt up against.
photoprado
