  • Hi All,
    AMTS, Thats what I'm after (Tyre Spacer, HF Mount + Telescopic Light)
    Please advise when you have one for the 120 series.
    Stuart
    PradoGXL08
    Stuart Trevena
    [COLOR="#FF0000"][B]2008 Prado GXL D4D 3.0L T/D 5 Speed Auto Colour: Dune with loads of Extras[/B][/COLOR][COLOR="#0000CD"] [B]and 2015 Tvan MK4 Murranji Offroad Camper[/B][/COLOR]
    • OK Stuart.
      I think the HF tuner might be sitting a bit high...
Name:	120 tyre spacer with light and hf mount 3.jpg
ID:	644659Click image for larger version
Name:	120 tyre spacer with light and hf mount 3 end view.jpg
        OK Stuart.
        [ATTACH=CONFIG]11646[/ATTACH][ATTACH=CONFIG]11647[/ATTACH]
        Hi Andrew,
        With mine the top of the tuner is level with the top of my Pioneer Platform and the base sits about 1/3 of the way down from the top mounting bolts for the spare wheel carrier. I can take some measurements and photo's if it will help - just let me know.
        • Yep, way too high then. Looks like it needs to come down 200mm. Pipe bender anyone?
            I've just been out to check and 200mm is about right based on your CAD drawings.
            • Thanks Trekkie. Back to the drawing board.
              • That looks GOLD!
                I need to mount my UHF aerial back there. We do a bit of shooting out of our prado and you cant see a big grey UHF aerial through a rifle scope at night...There have been a few aerial casualties
                [SIZE=1]2013 D4D Auto Crystal Pearl "Altitude" - Caloffroad Bilstein 3 inch lift, SPC UCA's, diff drop & sway bar ext. FJ Rims-ET15 285/70R17 Cooper ST Maxx. ARB deluxe colour coded bar. Lightforce 240 XGT's. Modified X9 winch, 6hp motor & 30m 10mm rope. Dual Batteries, Redarc-SBI212, Mk3 diode & custom wiring. Water watch. ARB compressor. Twine underbonnet shower. Scangauge II. Custom rear draws. TG150. Tectyle rust protection. GME 3600 UHF, AE4705 antenna. PWR ATF cooler. Genuine tow bar.[/SIZE]
                • Hi All,
                  The codan 9350 Aerial base is large / high we all know that, but the new codan 3040 is only 145 mm W x 165 mm D x 240 mm H (excludes spring and whip).
                  I trial fitted one to the Rear Tyre Spacer that a friend of mine made several years ago, and it fits perfectly.
                  I will try to get some pics when my Prado comes back from the installer of the HF.
                  Stuart
                  Stuart Trevena
                  • In that case, no pipe bender required then. But what about performance issues with shadowing from the roof and roof racks?
                    • I'll just leave these here....
ID:	644669Click image for larger version
                      • Thank you rwo for spending the time in helping to test out the prototype light pole bracket for the 150. Great outcome considering that we are 1500km apart.
                          Not a problem at all mate, happy to be able to give something back to the community!
                          • Had a better look today about mounting the HF antenna. Due to the wiper on the 120, it is impossible to place the telescopic light pole on the left of the spacer. So if the HF bracket is mounted, the antenna will come out to the right of the tyre and there will not be room for any telescopic light pole. However, there might be a possibility of a fixed pole attached to the horizontal pole.
Name:	120 tyre spacer with light and hf mount 4.jpg
                            Different story for the 150 as the wiper comes down from the spoiler. So the telescopic light can be on the left and HF antenna on the right.
                            amts
                            Ninja Poster.
                            • Can we start ordering them yet amts?
                              • I cna't get a hold of the 90 series owner so I'm going ahead with the light pole bracket for the 150. Probably order next week as I'll need to do it at the same time as the HF bracket prototype and another antenna/sandflag mtg bkt prototype I'm working on. I also have a full designed-from-scratch telescopic light pole which I'm trying to squeeze the price down and work out a minor detail. I'm heading off to the snow soon so I'll be testing out this new light pole. Hope to get pictures of this soon.
