120 Prado shift lever repair kit
Hi Andrew & All
Just fitted the new bullet and spring to the shift mechanism .
Happy to say that I can now select all gears with ease.
There was enough surplus white grease on the mechanism to lube the new pin and spring as well as a light coat on the shifter gate.!
This mod should be on everyones to do list-just like the Hilux washer jets.
Well done and thanks AMTSSOUTH AUSTRALIA GATEWAY TO THE OUTBACK!
Hi Andrew
Just fitted the new bullet, spring and washer. The photo instructions were easy to follow and the auto gear lever is working good as new. Would love to know where the old bullet went!!
Jim2004,GXL V6 Auto. ARB bullbar,IPF 900 spotlights, Milford cargo barrier, GME TX3400UHF, Coupler Tec, Cooper AT3's, Safari Snorkel, Dual batteries, King Springs and Bilsteins.
Lol good one Andrew. I should add that mine works a treat too. Much better than beforeOriginally posted by amts View PostGood to hear!
I was testing the new batch of bullets when mine fell into the side of the console and then under the carpet. The more I peeled back the carpet the further down it went. Eventually fished it out.
Sent from my iPad using TapatalkCheers
Blake
- 1 like
Email receivedOriginally posted by daddy54 View PostHi Andrew.
I hope I've got this posting process correct. Just a follow up message. I'm a new member appreciating this great forum and emailed you last evening re purchase of the kit. Will probably require 2 as my son also has same vehicle.
Many thanks.
I have had one of these floating around for a long time, seeing as I had the console apart again for the 50 millionth time doing some other work I thought I should do some preventative maintenance and fit it, piece of cake.
Just need to put everything else back together so I can drive the old girl and test it out
