120 Prado shift lever repair kit
  • #91
    Originally posted by mr180sx View Post
    Repair kit recieved and installed. Very easy to do with the instructions supplied. Would definately buy from andrew again. Thanks
    Gee that was quick!
    • #92
      Thanks Andrew, item received and put in, works great. Thanks for the clear instructions. Cheers Steve
      • #93
        Originally posted by MENT4L View Post
        Sorry for the maybe dumb question (can't see the photos on phone) but my 120 shifter is all sloppy and won't stay in 4th or L so will this solve it??
        Thanks in advance
        Trent
        Ok so after having my kit since June 2013 I finaly found the motivation to fit it (slack I know)
        Fitting instructions made the job so simple and yes it fixed the problem... thanks amts wish I had of done it sooner. Turns out it wasnt broken but the pin had fallen out, fitted the longer pin anyway
        • #94
          Thanks Andrew received and installed. works perfect.
          • #95
            Thanks for the feedback
            • #96
              Hi' Andrew,
              I don't have a problem yet to my 2004 Prado but I am interested to have one. I will be sending email to you shortly thanks.
              Hommer
              • #97
                My pin had come out, put it back in and tried again and it just keeps popping out. Will the new spring and pin fix this? Do I need a new lid as well?
                crabman
                • #98
                  Thats what mine did mate, the pin andrew supplies is longer so fixed mine
                  • #99
                    i'll be happy with that solution compared to replacing the entire box!!!!!!!
                    • Yes, new pin and spring will fix it. New lid is not required. The wear on the lid will still go on though. But probably another 5+ years of life reclaimed with the repair kit.
                      • So, sometimes it takes a while or a few goes tapping the lever left and right to get my auto box to grab L or 2nd. Does that sound like it would be related to this or is it an electrical selector or something?
                        Cheers, Leon
                        Optix Photographix
                        • Sounds electrical. You'll need to open up the shifter box and have a look. Normally the floppiness is in the left - right motions but the gear changes still reflect the position of the gear stick.
                          • That's what my mechanic said ... damn it when they're right
                            Cheers, Leon
                            Optix Photographix
                            • Originally posted by Snaga View Post
                              this probably wont solve your problem but for the few dollars it costs and the small amount of work to install its probably worth doing regardless, you might even fix your problem just by making sure electrical connections are all firmly plugged back together when you are installing amts kit, stranger things have happened
                              • Well I received my new kit from Andrew today. What a bloody beauty, fixed the problem. Toyota said I needed a whole new "shift box" $1047!!! $13.70 delivered from AMTS and is far better quality than the original.
                                Thankyou to Andrew for his help and patience (lots of emails as aussie post took a while lol) and also thanks to Prado Point. I know I don't post often but the help and advice that I have received from other members on this forum has been sensational.
                                Thank you very much
                                Richard.
