  • Haven't damaged a neighbours property since 1974 when I launched a bolt-bomb through my neighbours lounge room window. It went through the glass, through the venetians and embedded itself in the wall above their fire place. They were sitting (luckily) having afternoon tea. Needless to say I didn't sit down for a week after that courtesy of the old man.
    • Couple of easy mods today. I did the windscreen wiper jet upgrade using the cable tie method and replaced the ciggy plug with an anderson plug for my Engel fridge.
      2006 GXL 1KZ: ARB Bull-bar - Safari Snorkel - 2 inch lift - Spotlights - On board ARB compressor - Dual battery - Red Arc System - Full length alloy roof cage - 38L Engel fridge - Awning - UHF - Toyota tow ball - Polly airbags - Inverter - Reverse/ Camp LEDs - Rear door fold down table - Hilux windscreen jet upgrade - Custom rear drawers - Long handle shovel holder - Diff breathers
      • Got her in for a wheel alignment and balance and brake checked. Brake rotors need to be replaced as they are down to nearly bare minimum thickness :shocked: so they're getting replaced.
        Here are the alignment numbers
        • That' s a very detailed examination and readout. Nice work.
          [B]Robert
          • Moved the catch can from under the bell housing and into the engine bay hanging off the aux battery box. A little tight but works. Re-plumbed the input hose into the turbo:
            Next modified my home made bracket to suit the new location:
            Shortened all hoses and run them over the intercooler front bracket to keep away from exhaust manifold heat:
            Trimmed the engine cover slightly to fit over the upper hose:
            And I can just get my hand onto the oil dip-stick.
            • Went out today to buy a set of radiator hoses for spares - we're setting off across the paddock on Monday. Didnt want to pay Mr Toyota's price, so went to Supercheap - only available on special order. Went to AutoBarn and told them my tale of woe. I told the guy I bet he could find a hose for a 1979 Fairlane or similar, but not for my Prado. True enough - the very first hose on the shelf was for an old Fairlane
              After 5 minutes on the computer, he discovered that they can be obtained on special order. He wrote down the part number and sent me to Veales. They had none in stock, however they can get them in for the net day.
              Now I know that W.A. stands for "Wait Awhile" but that's ridiculous.
              • If all else fails try don kyatt spares in Kewdale they are the WA terrain tamer stockists I'm sure they would have a hose kit.
                Cheers Joel
                • Took it for a good highway run to clean out the cobwebs towing the van, Darlington Beach Caravan Park.
                  On the way down.
                  • Removed the leaky suspension airbag. Luckily I found that it was a whole in the hose, not the airbag.
                    So I cut out the section and got one of these from ENZED to repair. Much cheaper than a new airbag.!
                    • Recently had a fill up. Latest fuel consumption for my V6. 16.05L/100km good by your standards?
                        Recently had a fill up. Latest fuel consumption for my V6. 16.05L/100km good by your standards.
                        Mine's normally in the 15's. Low 15's if highway a lot. High 15's if city stuff and 4wding.
                        • Mine is always around 16 and above… I must have one heavy foot…
                          • Just did the 200k service
                            Replaced:
                            -Oil
                            -Oil Filter
                            -Fuel Filter
                            -Tank Fuel filter
                            -Air filter (just to be sure)
                            -Front and rear diff oils
                            giving it to repco to do the final checks and the brake fluid (got lazy here)
                            from my calculations It cost me about $230 in parts.
                            my last major service was $800ish and repco are charging $120
                            a nice big saving for some new bash plates..
                            • Fitted a snorkel
                              Hi peeps,
                              After running around the bush for a year without one.
                              Water on the windscreen at least twice - floated a bit only once.
                              Proved my point you don't need one.
                              Now I put one on.
                              Why.
                              Cos it looks good.
                              Tuffa.
                              Anth120playdo
                              Banned
                              • Image is everything.
