Muti-function Display
  • #76
    Once mine hits 0 DTE I reset the Odo and have gone another 130 kms after that, I usually go to 75 after DTE hits 0 to be safe.
    • #77
      Ive just been quoted 220 from a wreckers in perth. Fair price or keep looking?
      • #78
        Buy a scangauge, unless your Prado isn't OBD2.
        • #79
          That's approx. what I was quoted when I was looking
          • #80
            I got one from a wreckers in Qld for $100 posted to me in Adelaide. I found it through the Trading Post, the car had just arrived in stock. I believe they get snapped up pretty quickly. I was looking for a couple of months for mine but I was happy to wait so I have the factory look.
            2008 V6 GXL Graphite, Sovereign bar, LED spotties, BFG A/T tyres, King Springs on rear with KYB off road shocks, Engel 40lt fridge, Dual batteries, Uniden CB.
            • #81
              Picked up one of these bad boys. So easy to install, about 15 minutes.
              Powered on the car and its displayed in imperial! (actually wasn't too much a surprise, ebay pics showed it was imperial. I assumed the car ECU would send which type of measurement to use).
              Anyone know how to change the measurement type? I had a look at some of the American/Canadian forums and they suggest it can only be done at the dealer. I guess through an OBD cable and software..
              • #82
                I dont think it can be changed as the computer systems are all set up for non metric measurements. Sounds like it was out of a Lexus GX470 which was the Prado 120 series equivalent in the US but with a V8 engine. Keep looking in Aus and i am sure one will turn up. As i said i waited a couple of months but kept looking daily.
                • #83
                  I have a feeling you're the same guy from the Prado group on Facebook who just got the Lexus display. I'll just quote my comment:
                  "Try the mode button? �� sorry. I think it's programmed into the units board to read imperial. Not sure"
                  • #84
                    Cheers for the response. yeah, its from a lexus and yeah im the guy from the facebook group
                    "Lol yeah i tried mode hah. Tried holding mode and reset. Will play abit more. I have no problem learning to read imperial, building knowledge!"
                    No worries. If it cant be done then so be it. Still useful to have the info anyway.
                    • #85
                      least you said you can learn the imperial. i wouldnt be able to learn it haha metric master race
                      • #86
                        /Old thread bump!
                        I finally got around to doing this upgrade. I stalked a few wreckers on Gumtree until i found a local one that had a Grande. Quick call and found out that it was already gone! Apparently these are still hot property and this place quoted around $75. Luckily i soon found another and even better they only wanted $50 for it. Took all of about 10 minutes to install in the driveway. I had loosened the wiring loom bolt when removing the original unit, so i was disapointed to see that it didn't do anything except tell the time when i first tested. I soon realised my mistake and sure enough it works a treat!
                        The only weird thing i've noticed is the instant L/100km readout sits at 99.9 when you're not moving. According to the manual it's normal to see a high value when stopped but what a weird design? I thought it was a busted feature until i drove the car.
                        • #87
                          Any pictures of the unit and how it all fitted in?
                          • #88
                            Originally posted by Point View Post
                            /Old thread bump!
                            makes sense though, right? the engine is on, so you're using fuel... but you aren't moving. sooo... high fuel usage per 100km. *shrug*
                            i just bought one of these from a wrecker in QLD. hoping it just plugs and plays. didn't bother asking what year or fuel type it was from. just a 120 Prado.
                            • #89
                              /Old thread bump #2 !!
                              Apologies i missed this completely.
                              Yes it went in very easily. One plug on the back, the only difference is the new unit is longer (as in, extends deeper behind the dash).
                              • #90
                                I have often thought about the same thing for my 2005 GXL diesel, I'd be keen to find out if anyone has tried fitting one and how they went.
