Derek11's 2012 Blue Storm 150 GXL build up
  • Originally posted by Steve M View Post
    Derek just looked at your pics for wiring running out above rear cargo door. Not sure going by picture but where the wiring loom runs down from roof to under rear door rubber did you silicone that up as well ?? Reason I ask is that is the same spot the water on the 120's is getting in (where the two panels are joined together) and then follows the rubber down to the bottom and sits there and starts rusting.. I can see the wire loom goes back in behind the drivers side through the grommet but if the water is coming in from the top I presume it would continue to follow rubber door seal to the bottom ... Cheers Steve
    that's right Steve, its silastic in place where you said, the water should just drip off the bottom and not pool up anywhere
    • such a nice 150 mate, i didnt like them before but now I do!
      • Originally posted by prado2004 View Post
        Thanks Mate, i'm really happy how the rig is turning out.
        • Hey Derek,
          What did you have to do to the front mud flap to clear the 285's? Would you mind postin a photo or is it that simple?
          Reason I ask is I picked up my 285's on the weekend, yet havent taken delivery of our Prado yet (Wednesday 28th!!!). I still need to get the 3 inch lift (inc SPC UCA's) installed, and I want to arm myself with all the info I can before I fit the tyres.
          Chris
          [SIZE=1]2013 D4D Auto Crystal Pearl "Altitude" - Caloffroad Bilstein 3 inch lift, SPC UCA's, diff drop & sway bar ext. FJ Rims-ET15 285/70R17 Cooper ST Maxx. ARB deluxe colour coded bar. Lightforce 240 XGT's. Modified X9 winch, 6hp motor & 30m 10mm rope. Dual Batteries, Redarc-SBI212, Mk3 diode & custom wiring. Water watch. ARB compressor. Twine underbonnet shower. Scangauge II. Custom rear draws. TG150. Tectyle rust protection. GME 3600 UHF, AE4705 antenna. PWR ATF cooler. Genuine tow bar.[/SIZE]
          • Hi Chris,
            With the front mudflaps i cut out the area that was rubbing (drove around the block to see the rub marks). Some PPs on here have heated them up and moulded them away from the tyre, that is the way i should have gone. As now i will get after market one to fit as the originals are well butchered.
            Cheers Derek
            • just realised 1 year anniversary from starting this build thread
              • Happy anniversary.
                SOL.
                • Next mod, 3" redback exhaust, see if its here today, that will improve the drivability abit.
                  • Why did you settle on the 3 inch?
                    • Originally posted by Est_1982 View Post
                      reason being is all the info on PP and reading PP's experience with 3" exhaust. Its great having all that info here.
                      Cheers Derek
                      • Originally posted by derek11 View Post
                        Cheers Derek
                        Should make a noticeable difference for you Derek.
                        I will be interested to see if you get any fuel economy improvement. Pretty sure my economy hasn't got any better, but definately more responsive and better pulling under load.
                          Wheelin around Adelaide River Tracks
                          and added custom pin striping on this trip
                          Very Nice Build Derek!
                          Not many 150's that look this good. Great write up on your drowning last year, thoroughly enjoyed it and it's prompted me to check/update my insurance cover before my upcoming VIC High Country/SA trip, this November.
                          I'll have a free day mid November and will be in Adelaide, you mind me asking where these Adelaide River Tracks are?
                          Thanks Mate,
                          Jamie
                          2007 Update 120 D4D, GXL Auto Option Pack 1 - ARB winch bar, ARB UVP, ARB tradesman rack, 2" OME, Safari Snorkel, HR towbar, Tigerz11 12000lb Grande, IPF 900 Extreme, W602C, Hilux Scoop
                          My Build [url]http://www.pradopoint.com/showthread.php?28720-Jamie-s-Prado-120-D4D[/url]
                          • Jamie,
                            The Adelaide River tracks are in the Northern Territory near Adelaide River.
                            Winston.
                            Winston.
                            • Uh huh,
                              Must go to bed now, very late and must have been too tired to realize Derek is in NT (bloody PP build threads keeping me up!)
                              • Hi There Derek, mate that's one of the toughest 150's Ive seen around. You have done a top job and looks fantastic. Great to see you actually use it and not just a shopping trolley. Great going. Just read the whole of this post from start to finish. Didn't realize that was your prado that drowned and I saw that clip a while ago. Glad there were no issues with the insurance company.......I think you have ran out of things to do now lol.......Cheers Steve
