rhino rack "back bone" roof rack system
  • #46
    Originally posted by Nebulous View Post
    Hi Will, I have a RhinoRack Pioneer 42107B which is the 2128mm length model and it is fixed to the Prado using the 6 feet in the RLCP23 kit. When looking at the car from the side it appears that the rack does not sit more or less parallel to the line of the roof of the Prado, with the front tending to be higher than the back (have tried to attach photos). The front feet seem to be 15 -20mm too long/high (has anybody else noticed this), will the new backbone system correct this. Also, just a small thing, the Allen Keys with the hole in them seem to be a very poor fit and do not last long with frequent use when I have to frequently remove rack attachments to get into my garage. Cheers.
    Hi Nebulous, Pretty sure that is the same rack as mine, tray with permanent side rails on RLCP23 feet. Yes mine sits noticeably higher at the front than the rear but as the car sits bum high the tray is actually fairly level compared to the ground level
    • #47
      Nebulous,
      Make sure the feet are placed in the right spots as they are unique. The legs however are identical. Due to the extra length, it is probably just an optical illusion that the rack is higher at the front due to the roof curving down.
      As for the 'security' allen key, I just swapped them out with hex head bolts.
      • #48
        Hey Nebulous, just a thought, have you put a level on the rack? I just tried a level on my roof and it curves quite dramatcally as it gets closer to the front of the vehicle, it actually has a slight curve all the way from the rear rail mount point and is not level with the ground.
        I would think it would just make sense that the legs for the platform would keep the platform level to the ground and due to its length the front would be higher. As brogers said, the shorter platforms would not be so obvious in this regard.
        Check this out https://www.youtube.com/watch?v=kJOaZRsNLA4 shows exactly what we are talking about
        • #49
          Originally posted by Will_RhinoRack View Post
          Hey Guys, sorry for leaving you all hanging.
          Shorter Trays
          Unfortunately the current Backbone is incompatible with smaller trays - the logic behind this was to having the mounting points at the extreme lengths of the trays for better load distribution, also to make sure it looks as good as possible, we don't want the Backbone sticking out beyond the tray. HOWEVER we have heard enough requests to fit smaller trays - we received a sample this morning which shall allow for 1928 Length trays. I'll be sure to let you all know on that progress - keep crying out for it and it will certainly be heard.
          120 Prado Backbone
          A 120 has been measured up and it's currently in development. The process of getting these out in the market takes a little while, at a rough guess, we're looking at 3 months. Again, scream loud enough and I'll whack the afterburners on.
          amts - at this stage we're not certain the difference in height for the 120, but we will certainly be trying to get it as low as we can without compromising it's usability (strapping/ cleaning as mentioned before).
          rwo - Can you please let me know what system you're running on your legs? It's a Pioneer?
          OK here is my scream out loud for a Backbone to fit a 120!
          • #50
            Originally posted by The Bearded Pilot View Post
            I was told this weekend just gone that the backbone for the 150 Series and another vehicle are being re-engineered and that there should be a revised product by May this year.
            O Dog, hit up the guys at Pride Auto and see if they've had the same info.
            They told me, they have changed suppliers, and are apparently, on a boat.. Maybe that "slow boat from China".. The guys at pride auto, are giving me the six feet to use till the backbone arrives in May? But I don't really need to fit it just yet, big trip is in August, but at least, either way I'm covered.. I was just a bit pived yesterday, that I've paid for it in full, and nothing said about not being available.. Not really very nice thing to do what they did.. Imo..
            • #51
              Thanks for the comments everyone, When I said level with the roof maybe I should have said parallel to an imaginary straight roof line from front to back ( I know the roof is not a actual straight line) I might try and swap the two front feet with the two back ones and see how that looks, as Amts mentioned I'm pretty sure they are in the correct positions as per the instructions, but you never know it might have been a "typo" that Rhino-Rack did not pick up, I have seen a few others getting around that look the same and even photos of other PPers in other roof rack posts. There is nothing wrong with it just that it looks a bit "out of whack" and I thought I would bring it to the attention of Will at Rhino-Rack. Cheers.
              • #52
                Yea same i wont get mine until April apparently. Ordered it in January, 3 month wait ...
                • #53
                  the rack does not sit more or less parallel to the line of the roof of the Prado, with the front tending to be higher than the back (have tried to attach photos). The front feet seem to be 15 -20mm too long/high (has anybody else noticed this), Also, just a small thing, the Allen Keys with the hole in them seem to be a very poor fit and do not last long with frequent use when I have to frequently remove rack attachments to get into my garage. Cheers.
                  Hey Nebulous, I think you'll find with the Backbone it should have a "flatter" profile, following the line of the roof. Although it won't be absolutely even front and rear, it should be a little closer. With the lower profile you should hopefully notice a significant difference. From the image you've posted, I can absolutely see where your concern is. As a few others have stated, the longer trays certainly accentuate that difference.
                  In regards to the "Security" Allen keys. You'll find that a very large group of the Rhino Engineering team are on the same side as you (me included). I don't have any influence over the allen key situation but I believe there are plans on making a change.
                  Heard loud and clear! We had a 120 Prado in a few weeks ago and measured up. I'm currently in the process of drawing it up and receiving samples.
                  Originally posted by HaaHn View Post
                  Cheers Will, I am guessing it will be right but have thrown a tape measure on to give you the required measurements. Top edge of sunroof when tilted up is 38mm @ 800mm back from leading edge of roof/windscreen.
                  Hey HaaHn, thank you for the measurements, they definitely came in handy - the car we got in did not come with the sunroof.
                  I tested with the existing Backbone - we absolutely cleared the sunroof, based off of your dimensions. I will provide photos when I'm back at the work computer tomorrow.
                  I think 'Re-Engineered' is often misunderstood as 'design overhaul' etc etc. The design has been slightly adjusted to allow for faster fitment time and moving to a press tool. Absolutely everything else is the same. Take it from me, I 're-engineered' and designed it.
                  This could be the case, if you'd like to check the most current form of the RLCP instructions you can check out HERE
                  • #54
                    I'm really sorry to hear this guys - I'm not sure if I can offer much assistance other than seeing where they are on the water and bugging our suppliers.
                    • #55
                      Thanks for your concern Will_RhinoRack.. I had a bit of a rant, the other day, but got deleted.. Just if I'd known it would be 4 month wait, I would have just put a deposit, and happily waited.. But nothing was said.. I ordered mine from the Queanbeyan 4x4 show, and dealt with the Rhino rep.. As I said, nothing said about the supply issue, was told one to two week wait.. So paid the $1500 up front.. Would have been better to sit in my account for another 4 months, till the gear was here.. Over it now, all good.. Cheers Odog
                      • #56
                        O Dog - you haven't been deleted just your original 'cope this mate' post.
                        OldGreyFart
                        Terry
                        Canberra
                        • #57
                          New delivery date is now apparently mid May. That will make it almost a 4 Month wait! Will_RhinoRack any chance of some free tie downs for the ridiculous wait?
                          • #58
                            Hey Will, Cheers for that. Checked out the rack on Mike From Roof Racks Galore's Prado and am pretty sure she'll clear no probs at all. I'm keen for the 19** backbone, I think the 21** is just too long, and kinda defeats the purpose of a sunroof if you cover it completely with a rack.
                            Any chance the new one will be on display at the 4x4 show in Brissie on the 11th - 13th March??
                            • #59
                              Alright, just read this entire thread, Im sold on the Back Bone system over the ARB roof basket.
                              just wanting to know, what is the best/common width Pioneer Tray used on the 150 series? I think im going to use the 2000m x 1330mm #41104.
                              • #60
                                That's too wide. #41102 and #41107 is what is listed as being compatible for the 150 & 120 Prado.
                                http://vpm.cdn.rhinorack.com.au/Inst...ting_Chart.pdf
                                I personally would go for a Platform instead of a Tray. I have seen a few people wanting to swap from a tray to a platform. I find that there's no real benefit to a tray and besides, the tray adds weight which decreases the payload.
