There is only an extra 1776BTU/Hr for the 679 over the 678 or about 12% improvement in heat dissipation between the 678 and 679.
Model 678 13,934BTU/Hr
Model 679 15,710BTU/Hr
Given the tightness of space maybe not too great an advantage. I thought about the 679 but decided on the 678 due to space limitations.
Not sure where you got your dimensions from as the Davies Craig page link below shows the cores to be the same thickness 20mm the same length 281mm and only different in width 184mm versus 265mm.
Overall dimensions are the same for thickness 20mm and length 281mm differing only in width 213mm to 300mm
From The davies craig website (link below see page 59) the figures are
http://www.daviescraig.com.au/Images...ecs%202011.pdf
Prone
Prone
